Hello,
My 73 cb450's cluster does not light up. Anywhere I should check first?
Headlights and turn signals are working fine but the dash does not light up when I'm turning/ neutral/high beam or any lighting behind the speedos.
Thanks!
Check the bulbs first. A test light with alligator clips is handy for checking for power between the switch and the lights. A wiring diagram is always handy too.
Here is a modified diagram for a modern RR conversion but should be fine for you.
Any auto motive 12V test light or multi meter would be fine.
