Ok, so I'm making progress but still not all the way there... New points, condensor and coils, wires, spark plug caps, connectors, carbs clean, float height set properly, cleaned advance mechanism, etc. The bike fires up immediately and idles fairly smoothly at about 1500rpms(with the occasional popping on the right side). The left side seems to be working brilliantly. The right side on the other hand does not...
With both sides hooked up and firing, the bike will ride okay and rev up to about 4-5000rpms before bogging way down. (Parked, it'll rev up to the redline) If i lift the throttle on the right side carb, it'll start reving up to about 2000rpm then it'll bog way down. If I remove the left plug cap, and run solely on the right side, it completely dies.
Any ideas or things I should check? Thanks in advance!
-Brady
-Brady
