72 cb450. Starter makes a nose but does not turn engine. From what I 've read I'll need to replace or fix the starter clutch because they wear out and do not engage the engine, is this usually the case? or could it be something else?
313511
Remember that the starter clutch also involves the large sprocket....Verify that the projecting area of the sprocket where the clutch rollers engage is not overly worn as well.......
The clutch goes and does need rebuilding. The starter itself also. Just did both, not tough. Best
