I am installing a new starter clutch kit; installing the first spring and cap were easy and almost instantaneous. However, the second and third spring caps refuse to slide into their holes. It is as if they are a tiny bit too large in diameter. However, I tried to insert a spring with an old cap, and that cap wouldn't go in either.
I don't know if it matters, but when I pulled the clutch and rotor off, one roller was out of place and loose; one spring was about half the length of the replacements, and one spring was a bit shorter as well; two caps were missing altogether.
I examined the cap holes with a magnifying glass, and there does not appear to be anything blocking the way.
I am stumped; any help would be much appreciated.
Pix please..... Sounds like the missing "caps" are stuck in the remaining holes......
Sometimes I need my 10X jeweler's loupe.......Magnifying glass is typically 2X to 2.5 power.....
You were absolutely right. Once I removed them, the springs and caps went in nicely.
Now, isn't the clutch supposed to sit up against the large starter sprocket? Mine is sitting offset about a half-inch, and doesn't want to go any further.
Sprocket can only go in the depth of the steel clutch housing (I'm guessing that is about 12 or 13 mm max,... don't have one handy)...
I usually install the sprocket in the clutch (so I can check it locks in one rotational direction), and then install rotor, both sprockets and chain as a unit....Then reinstall guide clip.....
Don't forget to align the keyway and verify woodruff key positioning as you do this....
Replacing all as a unit helped a great deal; now I have about an eighth of an inch gap between the large starter sprocket and the clutch. Is that correct? BTW, thank you for your patience.
^^^well, at least for the starter clutch... there are a few other idiosyncrasies of the DOHC 450 to be discovered eventually if you have to go into the engine :D
