1 - 2 of 2 Posts
Hey everyone, I'm in need of some guidance. The the outer carb lever on the right side doesn't seem to be coming back to flush on the adjuster screws when I let off the throttle. At first the bike would start up and immediately go to a 4-5k rev, and I'd have to press the lever down to get it to idle properly, but now I can't get it to run for more than a second or two, which I'm guessing it being stuck open has flooded the carbs. I've tried shooting a little wd40 on the outside hoping that would help lube the process, but that's a no go. The coil spring on the inside of the carb seems to have plenty of strength, but I can feel that the outside lever isn't moving as freely as the one on the left carb. I have checked the throttle cable and it's got the recommended amount of free play so it's not over tensioned. This is my first bike and I've only had it a couple weeks so I don't know much, so I don't know really what might be causing it. I don't know if it helps to know that I've taken the tank off a couple times to inspect some wiring, so the system may have gotten a little dry, but like I said, I've had it running a couple times since. I suppose there's only one way to get to know the carburetor and that's to take it apart and go through it. I was hoping to have some sort of educated approach instead of going in blind, which is where you all come in! Any insight would be helpful and I would be very appreciative to receive it.
Thanks in advance!
Discussion Starter #2
I found that I had pinched the throttle cable between the tank and the frame when I removed it and replaced it. Problem solved.
1 - 2 of 2 Posts
