1 - 2 of 2 Posts
I've got an idea and I'm trying to find out what serial number rage would be correct for a CB450 K1 upper engine case.
Motorera.com states the frame no range for the K1 from CB450-3000001 to CB450-3008955 (only 8955 made?!).
Would this range also be correct for the engine no?
Ronnie, Engine numbers seldom matched, and were usually just "similar".....Ideally your range is correct, but in reality it is likely that any 300XXXX sequence engine could have been in there..... A 301XXXX would definately be a K2 however, so yes, there were less than 10,000 K1's...........(as far as my references go)
1 - 2 of 2 Posts
