My original is still working on the '70 450 but in case it goes does anyone know where one could be purchased? Doesn't appear to be an off the shelf at the auto parts store type.
I looked up 68, 71, & 74 on bike bandit. All showed still availabe from Honda.
If you have that weird 6 3/8 sealed beam, www.candlepower.com will have a bolt in H4 headlamp.
you will have to buy the 45/45w H4 bulb separately though.
If it is a 5 3/4 or 7 inch sealed beam there are H4 replacements available.
These will take the 45/45w bulb also.
I can't tell which size the later 450's used from the diagram, just that it looks like a standard sealed beam.
If you have the charging system capacity, those two can be had in 55/65w versions almost anyplace.
Just look for a sealed beam for an older car. The HO ones are best.
Great, thanks guys. Can't believe my headlight has survived all these years, but if it goes out I'd like to be able to find a replacement.
