Bill, In your instructions, you stated "Now screw the idle speed adjuster screws back in till they make contact, then give them another full turn or so - enough to get the bike idling."
The "then give them another turn or so" Might cause someone to bury/break the tip and/or damage the passage.... You need to edit it to read: "then turn them back out a full turn or so....." and , I'd make it "till they JUST make contact" (before that) as well.....
Just a suggestion.... Steve
Discussion Starter · #2 ·
Sorry, I apparently was looking at the following pic of the mixture screw when I read "idle screw" and the brain immediately cross-referenced and confused/transposed the two..... I guess that is a symptom of another problem with "old-timer's disease"......(Brain farts)....OOPS! :oops: ...Re-reading while fully awake, it makes perfect sense as it is...
Steve
Thanks for the info! I am about to clean my carbs for the first time (I've been spoiled with a '06 FI bike before picking up my CB360t which has CB450 carbs).
