My right cylinder is running rich and miss firing. Checked timing and carbs. Checked spark. All look good. Checked compression - 140 psi in left but only 90 in right. Adjusted valve clearance according to the manual. No change. I think I need to do a valve job on the old girl (1967).
I've been looking for posts on the subject but can't find any. Any suggestions would be welcome.
Also, do I need to buy a chain break and rivet tool? Any tips for keeping the chain from falling into crank case? Can I get this done without removing engine from frame? Any advice on where to buy parts if needed? Any other tips?
Thanks
Thanks
