3/8ths impact
Sent from my SM-A135U1 using Tapatalk
Did you check it out on the crankshaft, without the chain on it, to see if it locked and unlocked correctly? That might show where the noise is, if it's not the chain hitting the castings. Did you make sure the plate that holds the rollers in the channels isn't worn - if it's worn enough, the rollers can turn sideways.
Thanks! I checked on the crank shaft and off and seemed to lock unlock as expected. I didn’t check the plate as it was on nice and tight so didn’t want to remove. But I think based on your comments I will check the plate as it’s the only thing else I can think to check! Chain is a bit loose but seeing that sometimes it doesn’t make it, hopefully it’s the plate.Did you check it out on the crankshaft, without the chain on it, to see if it locked and unlocked correctly? That might show where the noise is, if it's not the chain hitting the castings. Did you make sure the plate that holds the rollers in the channels isn't worn - if it's worn enough, the rollers can turn sideways.
Only if the car is running.FYI - I'm using a car battery to turn it over, no chance this is causing an issue?
