Yes. Just pick out the old one and slip in the new one.
I did a quick write-up on this for the CB350.
Tachometer oil seal | CB350 Restore
Long story short, you should be able to pull the driver off the end of the assembly that interfaces with the camshaft, and the seal will come with it.
These models are driven off the oil pump inside the right case cover
I removed the tach cable but can't get the seal out so looks like I will have to remove the Rh crankshaft casing to get it out.
