Up for sale is a Honda Matic Gage Cluster.
I have powered it up and all seems to be working. I would suggest it be torn down, cleaned and lubed as it has sat for 15 years.
I do not have the key.
$100 including shipping CONUS.
I have lots more parts including the complete motor/transmission if anyone is looking for parts. I'll be posting more as I get them cleaned up.
314932
314933
314934
314935
314936
314937
314938
CB or CM ? Do you have the carbs ,carb insulators, change switch and rely ?
Thanks
Bill H
I have various parts for CB400 A & T. Obviously these gages are from the CB400A.
I bought a complete CB400t and the guy gave me parts from 2 other CB400t and a CB400a.
Yes I have three sets of carbs I can sell with insulators. I will have to look and see if the change switch is still in the motor. Not sure about the relay.
Carbs I am interested in are for the CB 400 A. CV type 28 mm, # VB24A. If you have the change switch test it. Set your ohm meter on continuity put + on one of the wires and - on the switch body. Should read 0. Slowly move the plunger into the switch and you should get a reading. Doesnt mater witch wire.
Thanks
Bill H
Hi there; looking for carb insulator for
Hi there; looking for carb insulator(s) for a 1983 cm 450a hondamatic. Please let me know if you come across any.
Thanks, Thorinn
