Bought this 1976 cb360t with essentially the entire front disc brake assembly missing. currently in the process of buying the parts I need to rebuild the front brake from the ground up.
So far I’ve successfully gathered all the caliper parts, master cylinder, brake lines, three way joint, banjo bolts and washers, and brake pressure switch. now my only problem is determining what else I’m missing, specifically around the three way joint. pictured is the three way joint, which is the junction at which the two soft lines go into, mounted in between the front forks.
311332
311333
basically what I’m asking is if anyone knows what this area of the assembly looks like, because I can’t find any detailed pics online. I’ve looked at part diagrams but they’re pretty hard to visualize and determine what I’m missing. I’m thinking I may be missing an extra bracket that mounts behind/in front of the three way piece?
