1 - 1 of 1 Posts
Hi,
i run on my 1977 CB360G the VM30 carbs with the following setup:
- Main Jets: 150
- Pilot Jet: 25
- Needle Jet: 159 P-5
- Needle: 6F4
- needle position: leanest position
- slide: 2.5
- K&N Airfilters
- Mikuni Intakes
This setup i also run on my 1973 CB350K and i runs great. But on the 360 the engine stutters a lot, especially in the low RPMs. The sparks are often black. The engine is overhauled 1.800 km before (2nd size pistons, new valves, rockers, camshaft etc). The carbs are synced, intakes are leakproofed, valves and timing is adjusted.
Is there a special setup for the 360s?
1 - 1 of 1 Posts
