Sounds like you need to check out the spark advancer, it may need to be freed up and lubed.
Already did. Its fully freed up and lubed. Maybe I placed the actual timing cam 180 degrees out of alignment when I reinstalled it in the advancer? I will check.Sounds like you need to check out the spark advancer, it may need to be freed up and lubed.
