So I picked up this CB360 a couple of weeks back. Previous owner put in a new battery. When I got the bike, it ran pretty good. Over the past week I've been ironing out some running issues, mainly found intake and exhaust leaks. I also adjusted the clutch. So I take it out for a spin, get a few blocks away and come to a stop, and the bike dies. Kick start it, and it doesnt want to stay running. Limp the bike home, and smell clutch. So I chalk it up to a poor adjustment. Readjust, and re-ride. Runs great, idles, get down the block again, and same story. Limp it back home and start thinking. So I've noticed that over the past week of riding, the electric start works less and less, and now it doesnt seem to have enough juice to start the bike. So after doing some research, I figure it's the rectifier. It's original, and I test it via the Clymer manual, and get no continuity. Problem solved, right? Wrong. I get the Radio Shack replacement, and wire it up and check continuity via the Clymer manual procedure again. (negative probe on green wire, positive on red/white, yellow, and pink) Neither of the replacements show continuity. But if I reverse the positive and negative probes and voila, continuity. I recheck the old one, and it shows continuity in this manner too.
Now I'm at a loss. I plug back in the new rectifier, and fire the bike up. Seems to run pretty good, but then again it ran good in the first place anyways, until i get down the street.
Has anyone had similar problems, or have any idea what's going on with the rectifier or what to check next? The bike's run pretty good since I got it, just seems to run worse over the course of the past week. I have no idea why the electric start worked a week ago, and has worked less and less ever since until now when the bike doesnt run good either. One last thing, I noticed that now the headlight gets brighter when I rev the throttle.
Help?
-MK
Help?
-MK
