it seems that I'm not getting all the power I should be getting, the throttle is very touchy and if I pull all the back at once it will only go to about 3.5-4k Rpms, what could cause this? Maybe resinc the carbs? Thanks in advance for your guys help! Very much appreciated ( 1975 Honda cb360t)
There are several possibilities...... The most obvious is it is only running on one cylinder.......
Why is another story.....Check compression, spark and spark timing including advance, and verify the both cylinders are getting a proper fuel/air mixture....
At least one of those is incorrect for at least one cylinder....
A compression gauge, a strobe, and a spray can of ether is enough to get an idea where the problem actually lies.....
If you need help verifying anything, feel free to phone...540-525-5199....Steve
Also, for everyone out there, where is the best / or cheapest place to buy tires for a cb360? And what would be best for just a cruiser, not going into the whole cafe racer ordeal, thanks in advance once again!
