Alright so i did a bit more work on her today and found some stuff i've never noticed/and been able to fix finally.
Finished welding the small spots it was leakin the in mufflers. Also instead of attempting to reweld all the rusty steel in the baffle plate i just took an air hammer and put about 6 holes in each one to "balance" the bad muffler with the half decent one. Seemed to make the engine idle better and now it has more of a harley sound lol. I still need torpedo's but this is a cheap fix.
Next i adjusted the floats higher. I ordered carb kits but those won't be here till like wednesday of this week. This was more or less a test to see if it would work. Bike started easier, not nearly as much cranking and throttle needed. 1 Gear, all the way to 8K not one misfire or buck. 2nd, just as strong. Stop sign.............stall lol.
So satified with the idea i left them be till i get my parts in and i'll reset them and see what happens. Plugs are still black, just not as wet looking.
So while it was idling in my driveway, i would rev it a few times and it would crack on the R cyl. I then noticed a back fire shooting out between the carbs and head.
Ah hah! An air leak, i'm not sure why i did this but i didn't put any RTV of any sort on the gasket surface. So i took off the carb boots, hondabond on both sides of the gasket, rebolted, bike revs down very quick now and crackle is gone. I'm done with it now, but glad to see i could finally make some sort of progress instead of going backwards for once.
