So I picked up one of these kits from CMC:
Honda CL / CJ / CB360 Oil Seal Kit | Common Motor Collective
Which contains the following seals:
- Shift Lever Seal
- Tach Cable Seal
- Clutch Rod Seal
- Drive Shaft Seal
- Cam Seal
- Kick Start Lever Seal
I am pretty confident about replacing the tach cable seal, cam seal, and the kick start lever seal. Before I start jabbing away, the drive shaft seal, clutch rod seal, and shift lever seal can all be replaced by picking at the seal from the outside right (engine side covers removed obviously)? No need to split the cases?
- Shift Lever Seal
- Tach Cable Seal
- Clutch Rod Seal
- Drive Shaft Seal
- Cam Seal
