Hi, the guy at my local bike shop sold me a cx500 regulator rectifier for use on my cb350. The wires all SEEM to make sense: 3 charging leads from the Stator, red wire to charge the battery, black wire to sense voltage and green to ground. Does anyone know if the yellow/white/pink from the 350 stator are a match to the 3 yellow on the cx500 regulator rectifier? I know pink is the "common" coming from the Stator and the yellow and white are lighting and ignition coils. Was the cx the same set up? If Not, may it work regardless?
Thanks
