Hi,
I've tried looking through this forum and couldn't find anything involving this issue for my 1971 Honda CB350 regarding the valve adjustments. This bike was previously owned by a little old lady who babied it. It had low miles and is unmolested. That being said I rebuilt the carbs, cleaned out the tank, new fuel lines, cleaned the electrical connections,
The last thing I wanted to do before I started it was to check the valve adjustment and adjust the cam chain. I turned the engine over until I lined up the LT mark with the timing mark and the piston is up at the top of the cylinder (I visually/physically checked it). When I checked the rocker arms they were tight and felt as if they were pressing down on the valves. I tried loosing them up but there wasn't enough play to make them loose as stated in the manual. There is still compression though as I can feel it as I turn the engine over. I tried turning the engine over 360 degrees and the same issue occurred. The only place I can feel the rocker arms loose is just before or just after TDC. Do any of you think that it is possible that someone took this stator out and didn't put it back in correctly?
The valve adjustment is pretty straightforward for this...but something doesn't seem right with this. Any help would be appreciated.
