I know i missed the boat on the last bushings order. if anyone has a spare set, please let me know. i'm getting my frame powdercoated this weekend so it would be a good time to put in some new ones.
cheers
dan
Re: CB350 Bushings
All Balls racing will make you a set of needle roller bearings to order...
I edited in the word "swingarm" in the title. I've never heard of AllBalls doing such a thing.. Do tell??
All Balls does needle bearing suspension kits for the MX crowd for swingarms and shock linkages.
I called up their custom order group and talked to a guy named Alex Geiger. we went through the specs on the stock swingarm id, the swingarm bolt OD and the overall width of the swingarm bushings. he said they can probably come up with a needle bearing solution that will work. suggested I send him the stock pieces to be sure. I haven't bought them yet. Am planning to run the bike ugly this season to work out any kinks in the build and powder coat the frame next winter after I'm sure all the welding is done.
planning to come to a final swingarm bearing solution then.
