1 - 20 of 25 Posts
Hey,
So basically most of the stuff i've read about shorty mufflers with cb350's is that it won't work because of the back pressure, meaning you need more resistance on the air that is outputting from the pipes. Since stock pipes are longer than shorty's, they don't have this problem.
Well I love my shortys. They are loud and cool as ****. Sooo, i read somewhere that welding a washer to the end, or having the washer pivot on a bolt can add more resistance to the airflow out the exhaust.... Has anyone tried this????? Seems like an easy fix to a problem that has been haunting bobber/cafe customs for a bit.
This guy knows a lot and mentions this:
The airbox is a resonant chamber that helps the mid range flat spot if it is
designed correctly. But old time dirt track riders used to strip stock
airboxes off and clamp a piece of women's nylon stocking over the carburetor
mouth.
They might even oil the nylon to keep the dust from getting into their engine.
But, after every heat race they would find mysterious holes in the nylon,
caused by reverse air flow through the carburetor during the camshaft overlap
period when a pressure wave from the exhaust pipe would come back through the
open valves and out the carburetors.
If you stand off to the side of a motorcycle without an airbox and the
afternoon sunlight is right, you can actually see fuel/air mixture OUTSIDE
the carburetor mouths as the tuner rev's up the engine.
Hot rodders called this mist "standoff". If they didn't at least run a low
air filter, the standoff mist would ignite when the engine backfired through
the carb and they'd have an under hood fire.
A well-designed airbox keeps that fuel/air mix inside and sends a positive
pressure wave of about 1/4 of a pound towards the carburetors, working
against the adverse pressure wave from the exhaust pipe.
You can google for "helmholtz resonator" to read about airboxes, but
basically the volume in the airbox controls the frequency the box resonates
at, and the box has to have an inlet neck of a certain size and length or it
won't work at all.
HR's work over a wide range of engine RPM, but they mainly need to be
designed to overcome the flat spot that occurs around 5000 to 8000 rpm.
Dirt track and road racers thought that the way to get the most power was to
run open carburetors with velocity stacks, but they had the problem of all
that dust being sucked into the engine and wearing it out, so that's why K&N
filters and oiled foam pods were invented.
Dirt track riders used to take their mufflers off and just run a straight
pipe.
When the exhaust gases got to the end of the straight pipe, they would expand
rapidly, making a lot of noise, but a weak pressure wave would still come
back to the carbs, making the air flow the wrong way.
The factory road racing teams were experimenting with long duration camshafts
and open megaphone extractor exhaust systems, but the 'phones were very loud
and the engines had such a terrible flat spot the riders had to slip their
clutches to go around slow corners in 2nd gear.
Then the factory teams started putting a short section of reverse cone on the
end of the megaphone to help the flat spot and make the motorcycle more
rideable.
The earliest Honda CB750 four cylinder motorcycles had four exhaust pipes
that were *styled* like reverse cone megaphones seen on grand prix racers of
the 1960's, but they had baffles inside to quiet the noise down, and riders
weren't trying to race around using 10,000 RPM all the time, they were
putting around town and cruising on the highway using 4000 to 5000 RPM and
they
weren't even getting into the flat spot that occurs between 5000 and 7000 RPM.
The two mufflers that came stock on your CL350 were shaped like the old "pea
shooter" mufflers that came on 1960's British motorcycles like Triumph.
But Honda figured out that what they really needed to do was add a balance
tube between the two separate exhaust pipes before the pipe widened out into
the muffler. The balance tubes underneath the engine were actually larger in
diameter than the exhaust pipes they were welded to.
These balance tubes gave the engine more midrange torque, and the Japanese
motorcycle factories, especially Suzuki, were using balance tubes to good
effect even up to a few years ago to smooth out the flat spot in the power
band.
And, tuners like Yoshimura were making the balance tubes into resonant
chambers that helped their highly tuned motorcycles accelerate out of corners
better by providing a bit of "back pressure".
You would see one of the chambers behind each pair of exhaust pipes on their
4-cylinder machines.
>Here is the complaint when im riding the bike and the
>motor hits around 5000 6000 rpm the motor starts to give this popping
>back fire and eventually bogs down.
The mid range fuel air mixture is getting too lean, the spark plug is getting
too hot and carburetor tuning won't do much for the problem because you have
the reverse air flow trying to come back out of the carburetor.
There is an idle mixture screw on the side of each carburetor, but you can
screw on that idle mixture screw all you want, and it still can't do anything
about the adverse pressure wave blowing backwards through the carburetor.
A carburetor is a stupid device, it doesn't know which way the air is going,
it sucks gasoline out of the float bowl when the air is going the wrong way,
and when the air goes the other way, it sucks up another shot of gasoline and
the mixture goes back and forth from being too lean to being too rich.
>I did some research and the
>remedys were to check ignition timing which is perfect,
NO! What a silly "boi" you are if you think like that!
The ignition timing is perfect according to what it says in the book. The
ignition timing in the shop manual is based upon your engine having the stock
airbox and the stock exhaust pipes.
The ignition timing in the manual is also a timing that you set when the
engine is running without any load on it.
The spark will occur when the voltage at the spark plug can overcome the
pressure in the cylinder. This happens some milliseconds AFTER the points
open.
If the spark plug gets too hot, the spark occurs *before* the points open,
and the engine pre-ignites.
Sustained pre-ignition will heat up the piston and melt a hole in the middle
of it.
Don't ask how I know that.
To get the ignition timing right with your K&N filters and low back pressure
exhaust system, you're going to have to experiment with retarding or
advancing the static ignition about 5 degrees and then do some acceleration
runs to find out how many degrees retarded or extra advance works best.
And this assumes that the spark plug you are using is the right heat range.
With open exhaust and no air box, you might want to run a spark plug that's
one or two heat ranges colder so you don't get pre-ignition from the spark
plug ground electrode glowing cherry red under lean mixture conditions.
If you run a colder spark plug to avoid preignition, don't blame me if the
engine is hard to start and runs crappy around town. We used to run hot spark
plugs for slow riding and switch to colder spark plugs when we went for long
rides at high speed on the highway.
> raise the needle which cant be done the 350 needles
Silly "boi". Of course the needles can be raised. Go to hardware store and
buy about 8 or 10 washers with 3mm holes in them and place a stack of washers
under the head of the needle and experiment with mid range mixture.
Of course the reverse flow problem still exists and the engine cannot suck in
any extra mixture with the air flow going the wrong way.
or put in a bigger main jets in so i did
>that. The stock main jet was a 115 so i put in 120 and i have 125s by
>the way.
Silly "boi". The main jets control the fuel air mixture when the throttle is
wide open and the the needle has lifted more than 75% of the way out of the
needle jet tube. Your problem is occuring at smaller throttle openings and
5000 to 7000 RPM. Mainjet size has very little effect on the problem you're
having.
I did some more research and found out that those small
>japaneese bikes need a lot of back pressure and i dont think that
>those shorty mufflers have enough knowing that the baffles are really
>thin so i made my own baffles i welded a fender washer to a bolt and
>bolted it inside of the muffler about a inch away from the opening on
>each pipe the bike sounds great but i am having the same problem but
>around 7000 8000 rpm.
In the late 1960's, riders who took the mufflers off their Honda 305cc
Scrambler were installing a device called "Snuff or Not". It was just a
baffle washer that plugged up the end of the exhaust pipes and reduced the
racket while they were riding around town.
Then they would rotate the washerinto the open position. It was like a
throttle butterfly in the exhaust pipe.
And computer controlled throttle butteflies in the exhaust pipe are used by
all the
Japanese superbikes nowadays. They are underneath the engine where the four
exhaust pipes come together at the collector.
>what should i do now any input is welcome please
The easiest thing to do is install the airbox with a new air filter, install
some original equipment peashooter mufflers, and return the carburetor
setting to stock.
Or, try to figure out what colder heat range spark plug you need now and play
with the static ignition setting, retarding or advancing the spark no more
than 5 degrees.
You can also weld a balance tube between the exhaust pipes, about 18 inches
from the cylinder head.
I'm not sure these bike have the valve overlap to send a very strong pressure pulse back through the carb. Everything you wrote sounds right but a cb350 is a different animal. Cv carbs respond to pressures upstream and down. Resonate air boxes are those big sealed plastic jobs on sport bikes, not old Hondas. Sounds like your thinking.. Get some books specific to the subject and ke reading. Let me know when you find the answer.
Dang, thought i was onto something... I mean if the resonant air boxes also have resistance, (I know i have V-stacks) what If I oil up the foam on the v-stacks with heavy oil to create resistance there as well.. then I would have sorta created less airflow and more resistance over the whole system... Obviously I don't have high tech measuring tools, so I won't be able to know exactly how to calibrate it, but do you think it's worth trying to re-create that resistance????
I know it seems like a waste of time, but unlocking this puzzle is also a great way to learn about these old systems... thus being able to customize it more... which is simply fun. Yea stock works fine, but thats no fun. ;)
I think the foam in your v stacks is creating too much resistance. I ran my 450 with open stacks/stock exhaust and it seemed to run fine. Eventually it blew a head gasket and the piston tops showed slight detonation or preignition pitting(I didn't re jet). The exhaust your running might cause stumbling and make it hard to maintain smooth cruising. I've read it's not such an issue on the 350. Best way to go about this-start with stock and change 1 thing at a time. When you experience an issue learn how your cv carb works (you don't actually control the slide) and try to determine where the pressures/airflow has changed and experiment to fix it. Ask others opinions-you may reason something is happening that's not. Then keep on going.
I have shorties on my CL350 with the stock air filters and stock jetting and it will rev cleanly as high as I dare to go. Had it that way for about 2 years now with no problems, other than a bit of a stumble at steady speeds in the mid-rpm range.
Sounds like you need one or the other.. lol. either stock airbox, or stock exhaust.. to get it at least sorta kinda good... I think i'm keeping my stacks and gonna put on stock exhaust pipes that are basically twice as long as the shorties...... Not sure what else to do at this point...
The cl pipes are longer than cb pipes. it's not the shorties per se, it's the overall system length.
The cl also makes 2 hp less than the cb stock because of the pipes.
yours is probably down an additional hp or 2 in the midrange over stock with those pipes.
its not a lot but when you consider a stock can puts down about 27 hp at the wheel and the cl puts out 25, and you loose 2 more...
23 is what's available IF everything else is in perfect tune.
personally I like going the other way and increasing hp and driveability
Reactions: dtsmjr8dan
That's why I'm working on reviving a stock exhaust system for it. Should have it on the bike sometime in April.
I'd guess cl pipes with shortys would be pretty equal to cl pipes with stock exhaust, unless there's a connection between the stock cl exhausts or its one big shared muffler?(I thought they were separate), either way, the extra volume would mostly make it quieter I'd think. Unless you can offer reasoning to the contrary.
length...if you want the cl pipes with shorties to equal stock performance, you'll need to lengthen the headers to get the tip all the way to the back of the bike...just like stock.
when I do my cl bikes I extend the cl headers back by welding in sections of CB headers before adding the mufflers or tips.
I figured shorties were about the same length as the stock cl mufflers. I'm trying to get at the reason why one system works better than another to help the op see how I'd go about tuning. What is the exhaust gas doing dynamically that effects power and if carb settings can be changed to help. I realize this can get to be a long discussion. I value your experience. My theory on correct length has to do with the initial slug of gas traveling down a pipe of correct length to help pull(scavenge) as much remaining low pressure exhaust gas out of the cylinder as it can before the valve closes. I'm pretty sure most 450 mufflers are long pipes for most of their length, if the CB mufflers are similar it would tell me the pipes need to be pretty long to get all the gasses scavenged. The pipes inside the mufflers are a bigger diameter too iirc so that tells me a constant diameter may actually be harmfully restrictive. If extra residual gasses are left from a inferior exhaust system can carb changes be effective? Timing changes? Again this is how I look at it and interested if others think I'm missing somthing
Discussion Starter · #12 ·
Welp, got the stock cb exhaust on... I can tell overall it runs better.. some more issues now. ;( It bogs down when i give it gas, probably at about 30% throttle it starts to bog down and the more gas i give it, the more it wants to stall.... It did this with the other exhaust, i just figured all my problems were with those shorty pipes... not so. lol
Also, I'm getting high revs at idle, which originally thought i fixed because i put newer carb boots on, which are sealed pretty good... I think it might be the felt washer in the butterfly clip is probably dry and letting air in..... SO close, yet so far.. :( any other thoughts on why it would rev high?
THanks for all the expertise!
As for the bogging problem when you open the throttle, I'd guess you have it jetted too rich. If the carbs aren't synchronized correctly, the engine won't drop back down to the proper idle when you close the throttle.
Yea, i mean stock is 105 and ive jetted the mains to 115 so that would make sense.. but shouldn't one up the jetting when using v-stacks?? I thought that was a must.?? Also, no oil in the foam, so not really much resistance..and it's also a thin layer like 1/4inch, and not super dense....
what do the plugs look like?
I'd put the stock 105 jets back in...by the way the 105s are the secondary jets...what do you have for the primaries? 68 is stock..what are you running?
also are your jets aftermarket or OEM honda? the aftermarket stuff is occasionally inaccurate...
I'd expect you'd need smaller jets with your carb setup not larger. filtered velocity stacks don't work very well. how did you mount them? the stock air boxes have rubber velocity stacks in them that open into a large dual chambered air box and are closely fitted to the carb mouth without any steps in them and do not block the air inlet for the slides in the bellmouth.
you need a lot of engineering to outdo honda...
Reactions: Lefty
Discussion Starter · #18 ·
Hmm, maybe thats it then... I think I need to put those back to 68, i have 70's... and 115 on the secondaries.. and the exhaust is stock.. so that probably explains some flubbing.. i'll have to put it back to stock...
Discussion Starter · #19 ·
Welp, put it back to stock... i think the flubbing is gone... It still revs high on it's own after being warmed up for a bit.... I replaced the carbs and carb boots completely, so those should be good...
Anything besides an air leak would cause it to rev high when warmed up???? I use the choke to the control the rpms ... I close the flap and cut off the air and it goes back down unless i choke it too much, then it cuts off.... Any ideas?
If the carbs aren't synchronized correctly the idle won't drop as it should. Could be some sort of "CV" problem with the stacks, too, or sticking slides.
1 - 20 of 25 Posts
