1 - 20 of 48 Posts
I am parting out a 73 Honda CB350G.
The engine is stuck. Right spark plug is missing and threads look pretty much stripped out. Crankshaft will turn slightly.
Speedometer gone, Headlight gone, Indicator lights gone.
Most parts are in average condition, nothing real special but mostly useable.
Seat needs to be recovered. Gas tank not too bad, needs cleaning and paint.
Send me an e'mail or pm and I can provide pictures.
Would be glad to send pics, just let me know which parts you're interested in.
I think most of the CL and CB parts are compatable except the exhaust and maybe different sprockets.
The 69 may have a seat that hinges from the back rather than the side. Other than that I think everything might fit.
Pulled the clutch out, cleaned it up and checked it over.
Friction plates measure .105 to .108, spec is .1031 to .1095.
Springs measure 1.270 to 1.280, spec is minimum 1.2305.
Steel plates are discolored, appears to be from sitting unused for several years rather than heat damage.
Would like to get $20 plus shipping.
Handlebars in decent shape, rust should be coverd by grips I think.
Right switch housing is there but PO cut the wire and the starter button is gone.
Planned on selling as a unit since the wiring looks like a pain in the butt to remove and may be darn near impossible to put back in but will part it out if someone wants pieces.
Edit: front fender and horn are gone.
As requested:
Fenders are pretty nice. Small dent in front fender between the forks. May be able to see it in photo. No rust on outside, inside should clean up reasonably well.
Rear fender has minor rust below tail light mount. Tail light lense is broken.
Horn looks good, sounds good, 1 screw mounting the horn to the bracket is broken off.
Update:
Found the CB350 model guide in the other (another?) HondaTwins site. It's actually a 73 CB350G (K5?). The hydraulic disk brake on the front should have given it away.
Other than that the differences appear to be mostly cosmetic and this thing doesn't have a lot of cosmetic left.
You mean this place???
http://www.motorera.com/honda/index.htm
It's been posted here dozens of times - bookmark it.
Maybe Jason could put it somewhere on the Links page (do we have a links page?) or make it a sticky somewhere????
Discussion Starter · #16 ·
Actually I found it on the hondatwins.com site on their resources page, but yours is even better. Thanks.
Discussion Starter · #19 ·
$10 will cover the shipping. That's $30 total for both carbs.
1 - 20 of 48 Posts
