I managed to bust a tang off my clutch basket. yay for frigid garages. so I have a few questions. are the two big gears behind the clutch basket bolted onto the basket or are the pressed. and whats the easiest way to get this basket off the shaft? I don't have any pullers that will grab right so i'm kind of in a ditch right now. i almost have the rolling chassis done and it was coming down to the simple task of going through the motor and doing the wiring. super yay. thanks for the help guys.
Woody.... You will have to remove the oil filter and oil pump, and one crankshaft gear to remove the clutch outer basket.... the "twin" gears are integral to the basket... Pulling on the basket as-is could damage the oil pump or the con-rod that drives its piston......You'll need the "special" socket to remove the oil filter "cup"..... (Motion Pro for about $10)..... Steve
again you saved my ass. thanks a ton for answering my crazy questions
where would be a good place to look for that assembly? am i looking to pay a high price cause of the age or are they realetively easy?
I probably have one I can spare...Give me until Monday to check, I'm out of town.... Steve
steve, someone needs to give you a medal
Woody....I have the clutch outer (with oil pump if you need it, or I can remove the pump if you prefer)...... E-mail me as [email protected] with your info so we can figure shipping cost........ Steve
I sent you an email. thakns a ton steve. Let me know what you come up with and your address in the reply. you truely are are champion
