When I first got my bike, I noticed that the headlight switch was a bit goofy. The taillight didn't want to work unless the switch was fiddled with and the gauge lights didn't work either. It seemed awful loose so I decided to look into the problem this weekend. Upon opening up the switch, this is what I found:
What is supposed to be holding the sliding part to the internal part of the switch? Is there supposed to be a screw? As you can see by the condition of the other screw heads, someone has been in here before to likely try and fix this problem.
