I've had an on-going issue where I get un-burnt oil from the left side exhaust. Given there's no smoke and the oil looks fine, I assume it's not entering the combustion chamber and is running down the exhaust valve. However, I just can't seem to find new guides and valves and am considering buying a whole CB cylinder head (as I'm in the UK and postage from the US is crazy) and using that instead.
I know that the cams are different, and I'd still use the SL one, but does anyone know a good reason why using a CB cylinder head would be a stupid idea and save me a few hundred pounds*
Thanks!
*FYI, since the stupid decision to leave Europe, a few hundred pounds £ is about three dollars
Thanks!
