On my CB360 rebuild, I also had a set of cylinder base gaskets from CMC. When pressing them into the groove, I used the blunt end of a metal pick to press them in. It was a bit annoying because whenever I would press them down forcefully, a segment on the other side would pop up. The trick is to SLOWLY work them in a little bit at a time.
