mine are in terrible shape, i am not sure if i can even rebuild them. if I wanted to put two whole new carbs on what would I be looking for? is it super specific? can I search for some by size, do they need to be these exact ones or could I pull two off something else, sinc them up and play with jets or what? any help works thanks
I am no twin expert but, I am pretty sure you have to have CB/CL350 CV carbs, they are the same carb. I bought a pair of carbs for my 350 because a diaphragm had a hole in it and the price was right. You can find carbs on ebay.
How bad are your carbs, do the diaphragms have holes in them?
If it is just dirt and crud, soap and water will clean it perfectly.
Kits are still available.
New float valves are pretty much mandatory.
the floats are actually floating in a bucket and the diaphrams are ok. its the jets that i fear aren't coming out. i'll try and find a few pictures. i ordered a rebuld kit for them and i am going to try and get them going, but there are a few broken pieces on the body i'm nolt sure if i can overlook so i am just trying to see if there is an alternative.
