1 - 2 of 2 Posts
I put the second carb back on today and noticed that the idle screws were not returning to the throttle closed position :eek: . I did not adjust the linkage when I took the carbs off -I just removed the bracket that was screwed on to the carb body- so I assumed that it would go back to the same position. In trying to get it running before I turned up the idle so I'm sure they were returning all the way then. :?:
Thanks,
Larry
You may have "adjusted" the throttle cable, so they're being prevented from closing all the way.
Check the junction of the cable, where it goes from one cable to two. It's possible you may have pulled the ends out of their housings.
If that's ok, then use the adjusters at the end of the cables (at the carbs).
1 - 2 of 2 Posts
