1 - 2 of 2 Posts
Hello:
I need a float...
looking for the stock floats from a cb or cl 350K4 (or similar). I'll take any old floats even if one of the floats is bad. Hopefully I can find enough floats to piece together one or two good sets. I can repair most if they are not too badly damaged.
I also need 2 float bowls. the PO stripped out the threads for the drain bolt in both of mine.
thanks.
John
Have you tried this company :
http://www.siriusconinc.com/index.php
Just type in your bike model then under "select part" click on on "carb repair kits".
Fleabay did not show anything . Another company to give a call to is "Dime City Cycles"
at 727-386-9735, Pete usually picks up, their good people who should be able to help you.
1 - 2 of 2 Posts
