Hey guys I've been messing around with my '73 CB350 for a while now and every time I more a little forward with getting the bike in running condition I seem to find a new problem. I will give the story of the this never ending battle.
Bought this CB350 about 2 years ago, didn't run when I bought it. Turned out that one of the points wires wasn't connected and were pretty messed up on the contacts. At that point I replace the point, condenser and ran a new wire for the points wire that wasn't connected.
I bought new carburetor floats, and all the stock jetting figured I would just replace them. When I removed the old jets they were all the same sizing that I was putting back in, also checked them against what stock jetting should be. So I am figuring I am good at the carbs.
About two weeks ago the bike seemed to be running ok, it didn't like to get throttle fast and would bog down but it would idle. So I got insurance on the bike and took it to a big parking lot by my house to test ride. Started right up, but one I put it in 1st and got the clutch about 75% out it would bog down and die. When I was loading it into my truck I found out the left exhaust was cold as ice but the right was hot. Brought it back to the house looked like my problem was the carburetor from sitting the needle got stuck and would not let fuel in. After I fixed this the bike didn't want to run and would backfire so I checked everything, I set static timing again, cleaned the carbs, checked spark.
This is when everything started to get worse.
I then thought I was having a fuel issue as from the petcock I was only getting fuel to the right carb. Looked it up and this seems common, and is what the petcock should be doing.
I want to say my problem is a timing issue as when I pull the spark plugs out they are wet with gas and I have spark. But static timing should to be set (how I did the timing was with a test light, coming up on the compression stroke for each cylinder lining it up with fire mark and getting the light to just come on), I was thinking I might have messed up the wiring to the coils so I am attaching a picture of what I have. (From what I found yellow wire is the left points and the gray wire is the right points, connected the yellow wire to the yellow on the condenser and the gray new wire to the blue wire on the condenser, I know the left coil is after market and the right is stock) I even tried to spray starting fluid in the combustion chamber and try to start it and doesn't even want to do that, just backfires after a while. Also did a leak-down test and while I'm not great on compression I still have it in the good marking.
Willing to try anything at this point, figuring if I can't get the bike running I might bring it to someone. Usually never bring my projects to other people but I don't know if I have a choice.
