I have a problem with the shifter on my CB250 G5 (same as CB360).
The main gearchange mechanism works fine and the pawl at the top slides left/right ok. However, itdoesn't seem to engage with the Change Pin End Plate (star shaped thing). I can get the star plate to turn and select all gears withthe help of a screwdriver turning the central cross-head screw/bolt which holds the plate to the gearchange drum so I'm thinking that the pins behind the plate (see Fig.7) might be damaged.
I don't think that Honda used this specific design in many models, as far as I'm aware, so maybe not many of you will have come across this issue.
Any ideas?
Thanks
ps. the central screw appears to have a stripped head (previous owner?) so maybe this is a clue.
Any ideas?
Thanks
