1 - 2 of 2 Posts
i have 2 CB K4's and am looking for 2 tanks. Both are cafe racers so having original is not an issuue.. Ive seen CG125 tanks cheap on ebay, anyone tried these on a 250? measurements say it should fit but does it for certain? Alternatively . anyone know of a good welder in yorkshire.. I have rotten 250 tank needing repair
Cheers
Dave
If the measurements look good, I would buy from ebay. You can always do a little modding when it gets in, you just have to figure out the puzzle.
I would never trust a fouled tank. By the time tanks start to get those pinhole leaks, tracing them down and brazing them is not a good option. It is a temporary fix.Tanks are not like radiators. When you stop the pinhole leaking, you paint it ip, gas it up, and in a few months you have a chance of leaking again because now the pressure on the thin tank walls has found a new way out.
best to start with a better tank from a low moisture place or a new one.
1 - 2 of 2 Posts
