You should be able to swap carbs if you disconnect the choke linkage and operate them individually....Just for the test of course.....
HOWEVER, I would try adding fuel to the right side (spray ether) and see if it tries to run first....
Are the carbs synchronised by throttle pull and mix screw settings at least?
