You can try trimming the spark plug lead back about 1/2 an inch and twisting the boot back on. The boots (connector to spark plug) have an internal resistor and should have a value of 5k ohms (5000 ohms). The resistance increases as they age so it might be better to buy a new pair (~$12).
The spark plug leads are molded into the coil and are not replaceable. They get awfully brittle with age.
Having been through all this, I ended up getting a replacement coil and boots from MikesXS.com. Here's the coil, it bolts right on with no mods needed, is the correct value, and works great:
https://www.mikesxs.net/parts/yamah...nition-coil-oem-30400-306-672-4m4-82310-60-00
