mfdemasi said:
Should have a 1.5 ohm coil. i just swapped my oem coil for an aftermarket 1.5 ohm Dyna coil this season. Seems to work better than the original, and have put about 800 miles on it. Not 100% sure of the reliability yet, I would have to get back to you after doing more riding.
Stock is 3ohm for a reason
The 1.5 ohm coil should produce a higher voltage at the spark plug
BUT
at a the cost of duration
So a 1.5 ohm coil might produce 50,000 volts but the spark has short duration
A 5 ohm coil might produce lower voltage but the spark has a Long duration
Happy compromise 3ohm
If the plug only needs 10,000v to fire then the extra 40000v from the 1.5 ohm coil is wasted
what you want is a spark that is stong in both bright and long lasting
Also the lower impedance on the 1.5 should mean that the coil charges faster which puts a strain on the ignition system. Now if your running a total loss race bike with a 14000rpm redline then a 1.5 ohm coil will charge faster which is what you need because theres less time between firing and you trade a long duration spark for a fast charge
at a high rpm the coil shouldnt over heat but on a steet bike all the time away from redline will put extra ( unusable ) energy into the coil and they melt
Don't put a 1.5 ohm coil into a cb/cl200 unless you plan on redesigning the whole wiring harness to suit
