after a while the rpms. decline to a low idle, then eventually, stalls. the carbs and fuel are clean, and they don't respond to adjustment. in addition, the bike only revs. to 4 k on cold start. i don't beleive it is sucking air anywhere. Could it possibly be caused by an electrical issue ? any help would be greatly appreiciated, thanks, Rayco...
Fixed the category.......Please post pics and screw settings you currently have set.......
If screws won't adjust the carb, either carb passage or jet is dirty/plugged or parts are incorrectly installed......
Are the slide cut-aways facing the aircleaners? (Slides CAN be installed in the wrong carbs and fit, but won't function properly.....
