1 - 2 of 2 Posts
Have any of you replaced the springs on your advancer? I have a bogging down issue at high RPM and it's been suggested to me that perhaps the advancer springs are tired out. Have any of you run into an issue with the advancer springs? Anyone found a good replacement spring?
If the springs have weakened with age / use, all that means is that the ignition would go to full advance a little lower down the rpm range than before.
So provided that the ignition is correctly at full advance at 'high rpm', springs shouldn't be a problem, in my opinion.
Replacing the entire advance mech would probably be a better option than just replacing the springs if the unit really is faulty.
https://www.ebay.co.uk/itm/NOS-HONDA-CB200-CB200T-CL200-200-OEM-SPARK-ADVANCER-ASSY-30220-354-005/202084524963?hash=item2f0d2d23a3:g:f~4AAOSw9idZ5rxD
1 - 2 of 2 Posts
