Front brake worked okay when I got the bike, I took the brake apart to lube and replace the pads. When I put it all back together, I can no longer fit the barrel adjuster onto the cable. Even with the assembly out and fully compressed, there’s only about 1 1/2” of cable at the top. I can put it back together without the adjuster but would obviously rather not.
Any ideas what happened? It seems as if the cable housing is now too long, but that’s impossible. Here are some pics:
Auto part Engine Vehicle Brake Suspension
Auto part Suspension part Suspension Tire Automotive engine part
From what I remember the CB200T doesn't have a threaded upper/top barrel adjuster where it goes into the brake lever housing,only the one down on the caliper itself.Do you have a different front brake lever perch than stock ?
