OK, Bill, question-time again.
My (mom's) CB200 needs air filters, and I've read your description of how you did it, but I must be dense, here, I'm not "seeing" it...
If I burn that pleated paper and glue out, what keeps the rubber intake boot from melting, too?
Then, if you lay in a custom-cut bit of Uni foam from a sheet, where do you attach it? To the tiny little lip on that outer metal cover? With some glue? That lip is only ~ 1/8" wide. Did that work? Or, did you just cut a small bit of foam to cover up the opening where the rubber tube attaches?
Thanks,
Kirk
Thanks,
Kirk
