Built up my cb175 engine and when cranking it over to check oil is at the head I'm only getting oil out of the rear right hand head not the left nut if you were sitting on the bike.
I changed the oil pump to a cb200 item incase that was the issue but that just seemed to increase the amount of oil coming out the right nut.
Anyone had this issue before or have an advise on what to look at ?
Thank you
Luke
Yeah I had the cases vapour blasted and then cleaned out the oil ways. I have tried tightening the right one and still cranking but just don't seem to be getting oil.
I have been doing it with the starter just doing short 15/20 second cranks.
Might get the drill on the stator bolt later and crank it a bit more see if that produces oul.
