Hey guys, so I removed my fuel tank last night to work on getting the rust off the inside. I didn't realize that there is an extra foot or so of fuel line running from one side if the tank, under the frame, to the other, and spilled gas everywhere -_- I've never seen this on a fuel tank before, and I assume Honda put it on there to make sure the fuel gets used somewhat evenly on each side. The downside to this is that whenever you want to remove the tank, even if you drain it as much as possible from the petcock, there will be spillage. So, does anyone know if it's at all possible to remove the fuel tank without making a gigantic mess and having your moms garage smell like gasoline for 2 days? Thanks!
