I have a CL175 that I am getting running and it's missing the choke linkage that makes them move in unison. I wish I had tools for some simple metal working but I do not. Just wondering if anyone has some up with any clever household items that can double as the linkage? Just needs two holes in it and to be right length.
Wire from a coat hanger.
I thought about that. I'll give it a try I just need to find a wire hanger. Also need to see if I can get the end to bend tight enough to stay on the post. Thanks!
Use a pair of 10 gauge wire ring terminals for the ends with a piece of coat hanger wire between them. You could solder or epoxy the wire in the barrel ends of the terminals.
Reactions: Russ Lang
The ring terminals are a great idea. I just bent a coat hanger and it worked great. It's rigid enough to work just fine.
