looking for a replacement coil, on ebay I see a bunch of used ones and aftermarket reproductions. whats my best choice?
Any 5 ohm twin fire coil will work, a good used if you want to be period correct. They usually fail because 1. They get cooked 2. The HT lead's covers get damaged where they meet the coil body.
Aftermarket you get a skinny new part. Better comeback if it fails out of the box ( depending on the seller) but might need to file to fit ( mount holes)
The 4into1 coil I got for my cb160 was pretty good. I had to revert the wiring from the weird coil that was on it so I'm not sure if the wires fit right out of the box. The mounting holes were the correct distance apart.
Discussion Starter #5
what are the ohms for the 4into1?
