I finally finished (or so I thought) my 1970 CB175, I got a VT plate and reg, got my motorcycle permit and then this happens.
I can't get the thing to rev past 5000rpm, it just cuts out and barely runs on the left cylinder while the right dies completely. With the air filters off it runs perfect right to redline which obviously points to a rich mixture but I can't ride it without filters so I'm stumped. The bike has aftermarket pipes off an XS650 my dad had laying around, basically straight thru megaphones, they are proportionate to the bike and they do extend slightly past the rear axle.
I know plugs and ignition are all ok as it pulls great w/out air filters
So far I have done the following
-tried 3 new and used throttle needles
-tried the needles on 2nd, 3rd, and 4th grooves up from the bottom (runs best on 3rd worse on the other two)
-tried another throttle slide I had laying around just for kicks
-tried a CL #92 main jet in place of the #98 factory (only had one laying around so put it in the rich running rh cyl)
-I know how to adjust the air screws and have them set right (only helps from idle to 1/4 throttle anyway)
Before I assembled the bike my dads buddy (very meticulous guy worked at Honda dealers since these bikes were new until the late 90s) rebuilt the carbs for me with all new o rings and complete carb kits I purchased.
Motor does have good compression (I just did a light rebuild w/ new rings, all valves & seats cut and new intake valves) I wanna say it was about 140 with a long hose on the gauge which I know skews the reading
Any help with this issue is greatly appreciated, I am stumped and really want to get some riding in!
