Anyone out there know where I can find torque specs for engine rebuild?
I already have the cases split, and rebuilding the entire engine from ground up.
I have an old honda manual re-print, but it doesn't have any torque specs or tightening patterns for cases, or heads.
Is there a general rule that I can use? ie. 8mm bolts 12 ft/lbs, 10mm bolts 15 ft/lbs etc, etc?
Thanks in advance
Thanks in advance
