I am working on rebuilding a cb/cl160.
I recently rebuilt the cb160 engine. I have 2 different types of spark advancers, points plates and points. I am not sure at this point if the cam I put in the engine was from an early or later model cb/cl160. Does it make a difference with the type of spark advance and point set-up I use? Also, I am not sure which spark advance to use with which points plate..... or does it matter? I am assuming it does. Any advice would be much appreciated! Thank you,
Tyson
Use whichever one is in the best condition. Honda used parts several different suppliers. They are functionally the same.
