this may help with the pictures situation - I upload all my pics from a computer, it seems to be the most reliable method, but orientation is important here tooChanged to uploading pics with my laptop and seems a little better. I must say this board is not that easy to add attachments. Pics what to come in different sizes and orientation. Really strange.
Hmm well either way, looks like a near perfect cam. Good thing that chunk is out now, not sure how it would have been missed on a rebuild (or maybe it was top end only?). Here's what both of my cb160 cams looked like so you know how fortunate it is to find a cb160 with a good cam in itAs far as I can tell. I looked around the Web and posted on a few forums looking for lobe specs put couldn't find any. The two I have measure the same (except for an intake lobe that was flattened from a stuck valve in the locked engine) so I am assuming that it all stock. It looks like the CL engine has been gone through at some point in it's life and then not used very much. It was fairly clean inside. I did find a small chunk of wadded up aluminum in the crank case that was left behind from the previous rebuild.
