1 - 2 of 2 Posts
Hi Can anybody tell me if the fuel tap packing, part no 1699301100 and showing as no14 in the parts list is it just a 6 mm fibre washer or is it something special .I seem to be unable to get the tap to fully shut off i.e still dripping from carburettor feed pipes . If i remove the fuel tap cup, fuel is leaking past these packings .thank you Pete:grin: p.s I have replaced the lever ,spring washer and 4 hole sealing washer with new genuine parts
The rebuild kits come with metal washers, I had one petcock work after installing the rebuild kit, and one leaked all the time like yours. Maybe the surface the washers seal onto needs to be cleaner?
1 - 2 of 2 Posts
